I just received an 80 watt black and red laser. It came with a TL-410C controller. I down loaded the latest LB software and it communicates with the controller.
I can only get the start position to work with absolute coordinate. Even then the machine will go to the home position before it cuts the job. When using “current position” or “user origin” the machine goes to home position and displays a “out range” error. Is this a known problem? Are there any machine settings that need to be changed?
Is it worth changing to a ruida controller? I should have done more homework before getting this one! Which controller is recommended? 6445G?
