Starting a job in a perfect spot
I need to change a letter and then pick back up. Is this possible?
The only way to do that is to STOP the job,
-edit your change
  • click on PREVIEW
  • press play
  • move the slider to where you want the job to begin(skipping over the part already done
  • press START FROM HERE
Be sure not to move the media. I strongly recommend using the HOME command before you “start from here”
I also recommend that you time the break in execution to coincide with a readily identified position. I.E, between words or shapes.
Thank you so much I’m an hour and 41 minutes in and the last thing I want to do is send this thing back down and start over again. I really appreciate it!
It worked!! Wow, That’s awesome. Thank you for that. That’s about the first win I’ve had in a couple of weeks. I really appreciate you helping me. I have some things to work out on my setup or something but that just went perfectly!
