I had an issue with start and finishing cuts not being right. Finally fix most of the issue.
Now, if is cut a column of circles with lase laser head entering from the right no issue. From the left it seems to start about 0.2mm early and then then end of the cut it is out. moves to the following cuts with no issues. Done all the backlash and loss fixture checks, all good. If run the file again it start from the exact same (but early) position.
