Status changes from ready to disabled when transferring file from multi-ornament page to Lightburn work page
XTool d1 20W. GRBL. Lightburn 1.4.04. Prior to updating to v. 1.4.04, I was able to move ornament files from source page to Lightburn workspace with no problem. Now, after I copy an ornament file, as soon as I try to paste on newly opened Lightburn window, status changes immediately from READY to DISABLED. I am still able to select/move other ornament files from different folders (where files are listed individually, not multiple ornaments on a page). Everything worked prior to the update. Is there a fix for this or would uninstalling the newer version and reinstalling with older version be possible? Thanks in advance for the help.
What is a source page in this context? Is an ornament file a design file for an ornament or something else? What is the format of the file?
I assume you’re importing the file. Import won’t have any bearing on laser ready status but perhaps it’s updating during the import process.
Can you provide screenshots of the working scenario and the non-working scenario?
This is possible but unlikely to fix the issue unless you had a specific installation issue.
All releases can be found here:
Releases · LightBurnSoftware/deployment (github.com)
