was all going great and it finished cutting a job(i think it finished) and just stayed where it finished.
when i tried to move it home it made grinding noise and shook back and forth.
turned off machine and turned back on it homed to X and then shook and grind noise not hitting home.
things i have tried.
turned off machine and hand moved gantry is smooth in both directions.
turned on machine and hand moved gantry X axis not moved Y axis moves with like sand in bearings.
used key pad to move forward - back. press forward button once and it moves forward press again and it goes back. both while making grinding noise.
i will try and post Video.
any help would be most appreciated.
i am thinking maybe a poor connection or something.
kind regards
Mark
Thank you both for reply’s. so i put in rotary and same thing happened and i have just swapped motor plugs on psu and other motor is doing it now and y motor is okay.
Just for an up date. I found the issue.
It was the driver board. I had swapped around drive motor plug and each time it was same result fromthe one out put. I swapped board from other laser and all worked fine. New board arrived yesterday and all is up and running perfectly.
Thanks again for help.
