Still having alignment issues with all my files when updating to new 1.6
TEST 1.4.lbrn2 (130.2 KB)
FILE 1.6.03.lbrn2 (139.0 KB)
I am just wanting to update my Lightburn to the newer edition. I have been using the same Thunderlaser Nova 63 130W machine for over 2 years now. Haven’t moved a thing, same PC and same Machine. Like I said I was good on the updates until they went past 1.4.x and then that’s when I noticed all my files have changed.
Look at the number 1 on the 3 pointed dial from 1.4 to the 1.7. It has physically moved
Sorry I can’t reproduce the error. I picked up an old 1.4.0 lb version and started your 1.4 lbnr2 file, closed 1.4 down and start RC-3 1.7, picked up the saved file from 1.4, but everything is fine here with me.
You can try starting the saved file and see if it looks normal.
TEST-retur.lbrn2 (130.5 KB)
Just opened your 1.4 file with 1.7.00 an did a save test it please.
TEST 1.7.00.lbrn2 (158.7 KB)
With your 1.6.03 numbers aren’t aligned.
This is because of a bug introduced in between a couple of versions with letter spacing. These files have the HSpace set non-zero, and if you produced a file in between 1.4 and 1.5 with non-zero HSpace it will misalign slightly, and there’s not much I can do to fix it, unfortunately.
The alignment will only be off horizontally, and once you fix it, they’ll stay fixed.
I appreciate the answer. Running a huge Etsy store that uses hundreds and hundreds of files, and also working a full time job, I’m afraid I just will not have the time to go through all the files to correct the mistakes. So unfortunately I assume my updating Lightburn has come to an end after all these years (and I just paid for my license renewal 2 days ago to try 1.7). Looks like I am stuck somewhere in 1.4.x. If there is any other solution you may have please let me know.
Thanks to all who helped.
I reopened the file in 1.7 that you saved and it looks great! Unfortunately I have too many files to correct. Thanks for the help
When will the full regular release for 1.7 be available?
About a week after the last significant bugfix / report.
I did nothing just open-save.
Do you mind testing the following blind-shot:
  1. Install 1.7
  2. Create a new laser device by importing this GRBL-M3_to_M4.lbdev (16.0 KB).
  3. Select GRBL-M3_to_M4 device and open your TEST 1.4.lbrn2 (130.2 KB)
  4. Check if everything is fine.
  5. Come back with your findings.
