I still have some troubles with the Cut Optimization Settings: firstly the option “Choose corners, if possible” seems to have absolutely no effect, there ARE corners, but the cut DOESN’T start at them with no obvious reasons:
Also the “Cut in direction order” seems to be ignored or faulty, when using the option “From Bottom” combined with “Hide Backlash” and/or “Reduce direction changes” and/or “Reduce travel moves”.
Can you attach the file? If your shape is a collection of disconnected lines instead of a single, continuous loop, there will be no corners as far as LightBurn knows. Make sure that your shapes are all joined - Try un-grouping the shape, then using Alt+J (Edit > Auto-Join selected shapes).
Hide Backlash forces a specific movement pattern designed to reduce the effect of backlash. It overrules a good number of the more optimal decisions made in the cut planner, and there’s not really any getting around that.
