Stool d1pro extension
Ever since setting up extension kit my laser has not been running properly. Starts at different points than set. Does not home all the way. Can not start projects from center, user origin etc.
Any tips on things that will get this back to normal?
Although you need to configure your bed size in Lightburn (software)
I believe you need to contact XTool for setup your laser (hardware) new size correctly.
Hi.
Welcome to the LB forum @Ebogan .
^This.
There was a somewhat lengthy thread about that very issue a short while back, fortunately with a solution.
A very xTool-like solution I’m afraid, but a solution none the less.
Since I don’t have the enclosure for the extended bed yet, I haven’t presonally contacted xTool yet.
I do hope by the time I do have the enclosure, the remedy will be included in the revised lbdev file.
Regards,
Sam
:finland:
