So I cut out wedding tags on sample mdf and it gets like a lip or start stop bump you can see inside circle and edge I’m got a topwisdom controllerinbound7221518492988941143|374x500
What are your minimum and maximum power setting values? If you don’t set the minimum power high enough, it might not be enough to fire the laser tube at the beginning and end of the cut, and that could cause what you see here.
