Stop the laser before it reaches the end of the path
Hello.
I am not sure how to explain what I am trying to do, but I will try.
I made the line in the software which is 30mm long. So laser fires at the beginning of line and I need to shut the laser down on the 27th mm. When laser shuts down on 27th mm head will continue and finish the path on the 30th mm.
Is something like this possible? Or do I need to modify G code somehow?
Please help me, its very important for my project.
THANK YOU.
Make the line 27mm.
Make a line of 27mm with a layer and the power you need and a second one of 3mm with another layer at minimum power
I am sorry it will not work for me. I need to stop the fire and head needs to finish.
I did not think about it, but its a good idea, I will try it. So in this case I believe there is no function in the software to do it. Just some tricks.
Thank you.
It might be easier to assist you to your objective if you could elaborate on the reason to continue head movement after the 27 mm burn. You’ve posted in a Ruida forum, which implies that your code is not g-code based.
so? what’s happened? the trick works?
You need to update your profile, so we can see what this “laser” you list really is, exactly. Which controller drives this laser and which OS do you use?
As Roberto suggests, you can use 2 shapes to produce this movement. Yet, Fred is on point here, if you explain the task you are trying to accomplish, we may have additional workflows to offer. :slight_smile:
