When I finish engraving an image from a file I purchased on the internet, the laser stops in the upper left hand corner. I do have 0 identified lower left and the green box is there. Also, when I try to direct the laser in optimization setting to start at the top it starts the image at the bottom anyway. I do highlight cut in direction box and button from the top. I have also highlighted let the laser choose best starting point button. Is that overriding the cut direction? I assume it would be better to cut top down as my air assist is pointed toward the bottom
