Straighten lines
Was wondering if anyone has any tips on how to straighten jagged lines after tracing an image?
I’ve found that an easy way to accomplish your goal is to pick two points that are correct for the line you desire, then delete the nodes between them. Another option is to break the line at those selected nodes, delete the segment that results and add a new straight line between those nodes.
Why are you tracing a rectangle when you can create one without divots in Lightburn?
The way of deleting nodes is one way, another fast and easy way is to use the shape optimizer (though it depends on the shape if it works well:
Thank you for all these suggestions, I’ll try these out.
