Strange issue ungrouping
I am having a strange issue when ungrouping a specific object. It’s basically two rectangles that are grouped together and have a 8mm fillet on each corner. When I ungroup the filleted corners become rounded for no apparent reason.
Any help would be appreciated.
LightBurn
Hi @nickm324
I’ve tried recreating this a couple of different ways, but I’m not seeing the same behavior yet.
Could you attach the LightBurn project file containing that object before it is ungrouped?
It would also help to know:
  • Which LightBurn version are you using
  • your operating system — Windows/macOS/Linux
  • how the grouped shapes were created originally
  • whether they were drawn directly in LightBurn, imported from another program, duplicated/offset, or edited in some other way
No doubt you realize that ungrouping should only change the grouping/selection structure, not alter the corner geometry, so the original project file is likely the key thing we need to inspect.
Here is the project
Purchased File removed
LB version 2.1.02
windows 11
was an import of a project purchased on Etsy, although I have removed all the other parts but the problem still exists even with just the two rectangles in the project.
The solution is here:
for the next patch.
EDIT: Converted the shapes to image then Traced them:
@parsec While that is a work around, it still doesn’t explain why it does it in the first place when ungrouping.
@parsec I accidentally uploaded the full project by accident could you please delete it from your post as I don’t want to violate my purchase agreement from Etsy. The version with just the rectangles is re-attached to my other post.
Thanks.
Done and flagged for complete deletion.
Having the same issue with the latest version of Lightburn. I found if you open the SVG in inkscape, then copy and paste (not export) back into Lightburn, you won’t have the rounded corners.
This is happening to me as well.
Lightburn version: 2.1.02
Windows
Project created entirely in Lightburn.
That little square converts into a circle when I try to in-group all the project to modify the text.
I can’t recover that square because I need to ungroup to select the square individually and it concerts to a circle.
Hopefuly they are looking into this.
Can you upload this Lightburn (.lbrn2) file? I cannot imagine why it would do that.
This doesn’t make sense to me - if the shape is still a ShapeObject (A square with a radius perhaps) I could see that being possible but not likely.
And if I press again control+ u the other square on the left also becomes a circle. I’ve been using this file since version 1.6 and this problem appeared when I upgraded to 2.0 and still happens.
I can try to upload the file tomorrow.
Thanks
Attached is the minimal version of my project that demonstrates the issue.
Just ungroup the two boxes that have a filet on each corner and you will see the issue.
BabyPicFrameMin.lbrn2 (192.2 KB)
Did you create this file outside of Lightburn? When ungrouped, I get strange results with the Node Edit and Trim Shapes Tools.
If you did it entirely within Lightburn, please list the steps so we can exactly reproduce it.
I think this was fixed - Cut lines in .ai file change upon import to Lightburn - #7 by Rob11
That was 21 days ago and since nothing was mentioned about what release that fix would be in how do we know we don’t already have it and its still an issue?
Your file behaves as expected in my current dev version. This has been fixed and we’ll have a patch out soon. I’m checking with Adam about the timeline.
