Hi, I have a strange problem that I come to expose.
box.lbrn2 (300.0 KB)
Ortur Master 2 Pro laser machine connected to the COM7 port
Through the site Boxes.py I create a box with joints, I am attaching the file
The surfaces are very large and for this reason I have to engrave and cut the individual parts.
One at a time I start with the parts where there is the blue color level, everything is going well.
I start with a part where there is no blue color layer.
I start with the frame function, the Ortur does not start. I do the reset, nothing, it doesn’t work.
I skip the frame procedure, I give the start command, the machine starts to engrave and … after 10 seconds it stops!
I do not list how many times I have turned off the machine, how many times I have reset, how many times I have restarted the computer.
Another try, I import another SVG file and … everything works.
I deduce that the COM port 7 works regularly, that the software works regularly, that the Ortur works regularly
Another test: I have a second laser machine, Neje Master 2S Max, connected to the COM 4 port. I open the project of the box, I make the frame of the surface that did not work with the Ortur and with the Neje … it works!
I give the start and the work is finished regularly.
Another test: I invert the two ports, this time the Ortur is connected to the COM 4 port. Same problem, with the Ortur the work does not start.
Because it does not work ?
