I got excited I got home and had a slicer oper that could have been trying to communicate. But unfortunately no. Still the same issue. it is running the cutter but not doing the correct things.
This is some of the errors I get in the console
error:1
error:22
error:22
error:1
error:22
Starting stream
error:2
On or near line 0:
error:1
On or near line 3:
Stream completed in 0:00
ok
ok
ok
ok
Starting stream
error:1
On or near line 4:
ok
ok
Starting stream
error:2
On or near line 0:
ok
ok
Starting stream
error:2
On or near line 0:
**I turned on the debug log. **
Here is the result
22:26:38.533 D: “LightBurn 0.8.07” “Fri Mar 1 2019”
22:26:43.630 D: Enumerating ports:
22:26:43.630 D: “starting” busy: false state: 0
22:26:43.631 D: Port: “cu.Bluetooth-Incoming-Port”
22:26:43.631 D: PID: 0 VID: 0
22:26:43.631 D: Manufacturer: “”
22:26:43.631 D: Description: “incoming port - Bluetooth-Incoming-Port”
22:26:43.631 D: System Loc: “/dev/cu.Bluetooth-Incoming-Port”
22:26:43.631 D: Serial: “”
22:26:43.631 D:
22:26:43.631 D: Port: “tty.Bluetooth-Incoming-Port”
22:26:43.631 D: System Loc: “/dev/tty.Bluetooth-Incoming-Port”
22:26:43.631 D:
22:26:43.631 D: Port: “cu.usbmodem4993185B39341”
22:26:43.631 D: PID: 22336 VID: 1155
22:26:43.631 D: Manufacturer: “tomeko net”
22:26:43.631 D: Description: “STM32F103C8T6”
22:26:43.631 D: System Loc: “/dev/cu.usbmodem4993185B39341”
22:26:43.631 D: Serial: “4993185B3934”
22:26:43.631 D:
22:26:43.631 D: Port: “tty.usbmodem4993185B39341”
22:26:43.632 D: Description: “STM32F103C8T6”
22:26:43.632 D: System Loc: “/dev/tty.usbmodem4993185B39341”
22:26:43.632 D: Serial: “4993185B3934”
22:26:43.632 D:
22:26:43.682 D: Found port: PID 22336 VID 1155
22:26:43.682 D: Manufacturer: “tomeko net”
22:26:43.682 D: Product: “STM32F103C8T6”
22:26:43.682 D: Name: “cu.usbmodem4993185B39341”
22:26:43.697 D: Port open succeeded
22:26:43.731 D: “starting” busy: false state: 0
22:26:43.731 D: “switching to connect” busy: false state: 1
22:26:43.731 D: “Connecting…” busy: false state: 1
22:26:43.731 D: “Awaiting response…” busy: true state: 4
22:26:43.732 D: O: “24480a”
22:26:44.195 D: I: “6f6b0d0a6f6b0d0a6572726f723a310d0a”
22:26:44.196 D: I: “6572726f723a32320d0a6572726f723a32320d0a6572726f723a310d0a6572726f723a32320d0a”
22:26:47.100 D: got stream
22:26:47.100 D: S: 8 TB: 8 LC: 1 OK: 0 RC: 0
22:26:47.100 D: S: 4 TB: 12 LC: 2 OK: 0 RC: 0
22:26:47.100 D: S: 20 TB: 32 LC: 3 OK: 0 RC: 0
22:26:47.100 D: S: 4 TB: 36 LC: 4 OK: 0 RC: 0
22:26:47.101 D: O: “473231204735340a4739300a473120583132205933342046363030302053300a”
22:26:47.101 D: 36 bytes in 0.001 seconds, 36000 avg bytes per second
22:26:47.101 D: 4 lines @ 4000 avg lines per second
22:26:47.102 D: O: “4739300a”
22:26:47.103 D: I: “6572726f723a320d0a6f6b0d0a6f6b0d0a6f6b0d0a6572726f723a310d0a”
22:26:47.104 D: R: 8 TB: 28 OK: 0 RC: 1
22:26:47.104 D: I: “6f6b0d0a6f6b0d0a6f6b0d0a”
22:26:47.104 D: R: 4 TB: 24 OK: 1 RC: 2
22:26:47.104 D: R: 20 TB: 4 OK: 2 RC: 3
22:26:47.104 D: R: 4 TB: 0 OK: 3 RC: 4
22:26:47.557 D: I: “6f6b0d0a6f6b0d0a6f6b0d0a6f6b0d0a”
22:26:55.817 D: got stream
22:26:55.818 D: S: 8 TB: 8 LC: 1 OK: 0 RC: 0
22:26:55.818 D: S: 4 TB: 12 LC: 2 OK: 0 RC: 0
22:26:55.818 D: S: 20 TB: 32 LC: 3 OK: 0 RC: 0
22:26:55.818 D: S: 4 TB: 36 LC: 4 OK: 0 RC: 0
22:26:55.819 D: 36 bytes in 0.001 seconds, 36000 avg bytes per second
22:26:55.819 D: 4 lines @ 4000 avg lines per second
22:26:55.820 D: O: “473231204735340a4739300a473120583133205933332046363030302053300a4739300a”
22:26:55.822 D: I: “6f6b0d0a6f6b0d0a6f6b0d0a6f6b0d0a6572726f723a310d0a”
22:26:55.823 D: R: 8 TB: 28 OK: 1 RC: 1
22:26:55.823 D: R: 4 TB: 24 OK: 2 RC: 2
22:26:55.823 D: R: 20 TB: 4 OK: 3 RC: 3
22:26:55.823 D: R: 4 TB: 0 OK: 4 RC: 4
22:26:55.823 D: I: “6f6b0d0a6f6b0d0a”
22:27:00.472 D: 1 floaters
22:27:00.472 D: SpatialQuery build: 0
22:27:00.472 D: PathTree build: 0
22:27:00.474 D: Crossing time: 0 Output time: 1
22:27:00.474 D: Optimize by score: 0 ms
22:27:00.475 D: Protocol::GenerateCuts time: 0
22:27:00.476 D: got stream
22:27:00.477 D: S: 20 TB: 20 LC: 1 OK: 0 RC: 0
22:27:00.477 D: S: 4 TB: 24 LC: 2 OK: 0 RC: 0
22:27:00.477 D: S: 3 TB: 27 LC: 3 OK: 0 RC: 0
22:27:00.477 D: S: 3 TB: 30 LC: 4 OK: 0 RC: 0
22:27:00.477 D: S: 11 TB: 41 LC: 5 OK: 0 RC: 0
22:27:00.477 D: S: 4 TB: 45 LC: 6 OK: 0 RC: 0
22:27:00.477 D: S: 18 TB: 63 LC: 7 OK: 0 RC: 0
22:27:00.477 D: S: 10 TB: 73 LC: 8 OK: 0 RC: 0
22:27:00.477 D: S: 10 TB: 83 LC: 9 OK: 0 RC: 0
22:27:00.477 D: S: 10 TB: 93 LC: 10 OK: 0 RC: 0
22:27:00.477 D: S: 11 TB: 104 LC: 11 OK: 0 RC: 0
22:27:00.477 D: O: “473030204731372047343020473231204735340a4739300a4d340a4d380a47305834322e355938340a4739310a4731582d33322e354639303030533230300a4731592d302e3153300a”
22:27:00.477 D: S: 10 TB: 114 LC: 12 OK: 0 RC: 0
22:27:00.477 D: S: 10 TB: 124 LC: 13 OK: 0 RC: 0
22:27:00.479 D: O: “4731583635533230300a4731592d302e3153300a4731582d3635533230300a4731592d302e3153300a”
22:27:00.479 D: I: “6572726f723a320d0a6f6b0d0a6f6b0d0a6f6b0d0a”
22:27:00.480 D: R: 20 TB: 104 OK: 0 RC: 1
22:27:00.480 D: I: “6f6b0d0a6f6b0d0a6f6b0d0a6f6b0d0a”
22:27:00.480 D: R: 4 TB: 100 OK: 1 RC: 2
22:27:00.480 D: R: 3 TB: 97 OK: 2 RC: 3
22:27:00.480 D: R: 3 TB: 94 OK: 3 RC: 4
22:27:00.480 D: R: 11 TB: 83 OK: 4 RC: 5
22:27:00.480 D: R: 4 TB: 79 OK: 5 RC: 6
22:27:00.480 D: R: 18 TB: 61 OK: 6 RC: 7
22:27:00.480 D: R: 10 TB: 51 OK: 7 RC: 8
22:27:00.480 D: 13 lines @ 4333.33 avg lines per second
22:27:00.481 D: I: “6f6b0d0a6f6b0d0a”
22:27:00.482 D: I: “6f6b0d0a6f6b0d0a6f6b0d0a6f6b0d0a”
22:27:07.950 D: 1 floaters
22:27:07.950 D: SpatialQuery build: 0
22:27:07.951 D: PathTree build: 0
22:27:07.952 D: Crossing time: 0 Output time: 1
22:27:07.952 D: Optimize by score: 0 ms
22:27:07.953 D: Protocol::GenerateCuts time: 0
22:27:07.955 D: got stream
22:27:07.955 D: S: 20 TB: 20 LC: 1 OK: 0 RC: 0
22:27:07.956 D: S: 4 TB: 24 LC: 2 OK: 0 RC: 0
22:27:07.956 D: S: 3 TB: 27 LC: 3 OK: 0 RC: 0
22:27:07.956 D: S: 3 TB: 30 LC: 4 OK: 0 RC: 0
22:27:07.956 D: S: 11 TB: 41 LC: 5 OK: 0 RC: 0
22:27:07.956 D: S: 4 TB: 45 LC: 6 OK: 0 RC: 0
22:27:07.956 D: S: 18 TB: 63 LC: 7 OK: 0 RC: 0
22:27:07.956 D: S: 10 TB: 73 LC: 8 OK: 0 RC: 0
22:27:07.956 D: S: 10 TB: 83 LC: 9 OK: 0 RC: 0
22:27:07.956 D: S: 10 TB: 93 LC: 10 OK: 0 RC: 0
22:27:07.956 D: S: 11 TB: 104 LC: 11 OK: 0 RC: 0
22:27:07.956 D: S: 10 TB: 114 LC: 12 OK: 0 RC: 0
22:27:07.956 D: S: 10 TB: 124 LC: 13 OK: 0 RC: 0
22:27:07.957 D: O: “473030204731372047343020473231204735340a4739300a4d340a4d380a47305834322e355938340a4739310a4731582d33322e354639303030533230300a4731592d302e3153300a4731583635533230300a4731592d302e3153300a4731582d3635533230300a4731592d302e3153300a”
22:27:07.959 D: I: “6572726f723a320d0a6f6b0d0a6f6b0d0a6f6b0d0a6f6b0d0a6f6b0d0a”
22:27:07.960 D: R: 20 TB: 104 OK: 0 RC: 1
22:27:07.960 D: R: 4 TB: 100 OK: 1 RC: 2
22:27:07.960 D: R: 3 TB: 97 OK: 2 RC: 3
22:27:07.960 D: R: 3 TB: 94 OK: 3 RC: 4
22:27:07.960 D: R: 11 TB: 83 OK: 4 RC: 5
22:27:07.960 D: R: 4 TB: 79 OK: 5 RC: 6
22:27:07.960 D: 13 lines @ 2600 avg lines per second
22:27:07.960 D: I: “6f6b0d0a6f6b0d0a6f6b0d0a6f6b0d0a”
22:27:07.961 D: I: “6f6b0d0a6f6b0d0a”
