Hallo
Wenn ich ein Bild lasere mit Lightburn habe ich immer Streifen drin (siehe Foto)
Mit den gleichen Einstellungen in Laser GRBL läuft es ohne Probleme.
Wo kann der Fehler liegen ?
1200/15 (Weiße Fliese lackiert)
318dpi (imageR)
Jarvis oder Stucki
Bald ist die Lizenzfreie vorbei.
Werde die Software nicht kaufen wenn ich es nicht in den Griff bekomme.
Würde aber gerne mit Lightburn arbeiten.
That’s good. It looks like you may be able to still better optimize your setup so suggest you still go through an interval test.
Also, you may want to run some test patterns without constant power to get a better feeling for how it works. Constant power basically turns off the power modulation between min/max for speed changes. It’s usually something you want as it’s meant to reduce overburning at transitions.
Did you make any adjustments based on that? What are your new settings?
To me it looks like your Y-axis might be dragging a bit. Make sure you have proper tension on the belts. They should have no slack, be taught, but not stretching. You may have too much tension. Make sure the belts do not have any damage like broken or mangled teeth.
Check pinion on stepper to make sure it’s uniform in shape and rotating smoothly on the shaft.
Inspect wheels are properly aligned and moving freely on the rails. Make sure there’s no wobble of the wheels and that the wheels are round, not oblong.
Can you upload the .lbrn file here as well. Might be something in the file that’s causing problems.
I have already changed the belts (Gates G2T).
The tension should be such that the slide slowly slides at 45 degrees.
I have not made any other settings.
I don’t know which ones either.
Is my first laser …
while testing my new (and first) laser i had the same problems. I have noticed that the wheels on the Y-axis are not perfectly fitting the rails. I also have noticed that the wheels are already worn of a bit. At the moment i´m thinking about adding a linear-guide to the axis, making them more stiff, so my laser won´t wiggle at higher speeds.
For first help until i add the linear guides i have greased the wheels just a bit with oil used for sewing machines. It seemes to help against worn off wheels at least a bit.
