Hi everybody, Lightburn keep geting stuck on busy when I launch it because it fail to do the homing and when it happen, the console is not responding neither any of the button. I can’t do anyting with it. Sometime, after a few minutes, it shows an error message and the console become re-usable but it is not always and when it happen, it’s after a long time. Is there a way to solve this problem?
For info, I’m using an atomstack S10 Pro
Thanks in advance for your responses
If you have it set up to Auto-Home, and it cannot, there you go.
Does your machine have Home switches? If so, what corner? If so, where does it try to go when it is trying to Home. If it is towards the correct corner, does it try to perform the Home cycle as described below?
What is in the Console window when it fails? Copy/paste the text in a Reply.
HOME
- Trolley and gantry rapid move towards the switches.
- When the switches are hit, the machine will stop and reverse. First Zaxis must complete if installed, then X and Y. It may not reverse X or Y until both switches are found for X and Y.
- The machine will pull off the switches slowly until the switches open.
- The machine will reverse back onto the switches very slowly until the switches close.
- The machine will reverse and pull off the switches slowly until they open.
- The controller establishes this as the Home (and Origin) position. It is usually shown as something very close to 0,0 as the position if the controller is set for the first quadrant. If it shows large numbers, this can be changed with the G10 command or the CNC Mode switch.
There is no other version of the Home cycle. If you have limit switches, this is how it should work.
If you do not have limit switches, where it powers up is the Origin. Home is a machine mechanical function. Origin is a software design position. They are not the same thing.
