# Stuttering and Homing Issue With Comgrow Z1 (GRBL)
**URL:** <https://forum.lightburnsoftware.com/t/stuttering-and-homing-issue-with-comgrow-z1-grbl/58074>\
**Category:** GRBL\
**Created:** [January 23, 2022, 4:46am UTC](https://forum.lightburnsoftware.com/t/stuttering-and-homing-issue-with-comgrow-z1-grbl/58074 "2022-01-23T04:46:21Z")\
**Showing post:** 18
**Author:** ![TheCodeGeek](https://forum.lightburnsoftware.com/user_avatar/forum.lightburnsoftware.com/thecodegeek/32/36907_2.png) [@TheCodeGeek](https://forum.lightburnsoftware.com/u/TheCodeGeek)\
**Post date:** [January 29, 2022, 9:03pm UTC](https://forum.lightburnsoftware.com/t/stuttering-and-homing-issue-with-comgrow-z1-grbl/58074/18 "2022-01-29T21:03:16Z")
I wanted to share something that I found on this forum that I found to be very helpful. I found a [post](https://forum.lightburnsoftware.com/t/lightburn-raspberry-pi-trick-for-a-wireless-laser-cutter/47591) referring to some software called [VirtualHere](https://www.virtualhere.com/home) that allows you to connect to your devices over the network as if they were physically connected to your computer.
I pulled out my old Raspberry Pi 3B and using Raspberry Pi Imager, I imaged the Lite version of the default OS. I ran the script as suggested, connected my camera via a powered USB hub, and was successful in getting it to connect to my computer. But note, that The RPi could not be connected wirelessly, I had to connect the Pi using an ethernet cable, but my computer can connect wirelessly.
Now that the original problem has been solved, I will be starting a new post to log what I’m working on to share with others. I will include this topic for reference. Thanks for your help!
[https://forum.lightburnsoftware.com/t/comgrow-z1-10w-engraver-project/58733/2](https://forum.lightburnsoftware.com/t/comgrow-z1-10w-engraver-project/58733/2)
#Comgrow\_Z1
_[View the full topic](https://forum.lightburnsoftware.com/t/stuttering-and-homing-issue-with-comgrow-z1-grbl/58074)._
