Benda
(Ben)
July 30, 2022, 10:00am
1
Hello,
is there an option which prevents Lightburn to only do the first sub-layer if i press start?
This are my settings. “Output Sub-Layer” is enabled.
If i press start only the “remove coating” layer is processeed.
If select the second sub-layer in the layer panel, it process only the selected (second) layer.
Benda
(Ben)
August 1, 2022, 10:41am
2
If i have two sub-layers with one is ‘line’ and the second is ‘fill’ it process both layers.
If i have two ‘fill’ sub-layer it process only the first one.
I am the only one with this problem.
I am on Mac 12.5 with the 1.2.01
Benda
(Ben)
August 9, 2022, 9:42am
3
After uninstall and remove all related files from the system and install Lightburn again, everything works.
system
(system)
Closed
September 8, 2022, 9:43am
4
