Sudden change where settings aren't running as selected
SSSssoooo strange. Mira 7 original, Lightburn 3 years from the beginning. Haven’t downloaded the new release with the nesting feature yet. But the weirdest thing happened last night. I cut a customers project once a month for them. Same material, same everything. just open the file, load and go. Last night and today even tho my settings are the exact same my machine is moving way below the set speeds and therefore I ruined material. This is both engraving and cutting. What in the world has happened? Windows 10. I’ve not changed any settings anywhere at this time.
Hi Carol… The only outright thing that stands out is the mode, mm or inches. Double check your settings. This would likely be in Lightburn, most Chinese machines appear to use mm, not inches.
Does the Ruida complain on it’s console about anything?
:grinning_cat:
