Sudden move to origin during burn
With the pattern I currently want to burn, the laser moves to Origin after the first couple of lines.
The simulation is fine, but when I look at the gcode I see it:
G0X8.5Y6
; Layer C11
G0X8.5Y6
; Layer C11
G1Y5.87
G0Y5.82
G1Y5.75
G0X8.5Y5.5
; Layer C11
G1Y5.37
G0Y5.32
G1Y5.25
G0X8.5Y5
; Layer C11
G1X8.37
G0X8.32
G1X8.25
G0X0Y0 <-----------
; Layer C11
G0X8Y5
; Layer C11
This seems to be related to perforation mode. If I switch it off, no G0X0Y0 is generated. Just changing the Cut/Skip so this line gets more segments doesn’t get rid of the G0X0Y0.
Which version of Lightburn do you have installed? If this is a file you do not mind sharing, attaching the project file to this post may be helpful for troubleshooting.
floor.txt (56.9 KB)
floor2.txt (46.8 KB)
1.0.02, just started using it 2 days ago.
Sure, no problem.
The lbrn2 project file. The Gcode is helpful too though.
That second file is the lbrn2, the forum was not accepting it until I renamed it…
