In the draw lines: Adding a “close line” option to drawing lines. Currently in an embroidery software I use when drawing lines you are able to close the line by drawing making a few nodes then instead of trying to snap the first node you can type “c” to automatically close the line to the beginning node.
I currently have ‘C’ as ‘Corner’, but it would be easy enough to make ‘S’ (smooth node) toggle the Smooth/Corner state. I’ll think about it - it’s not hard to make the feature, just need to find a key that makes sense.
The close line feature only works when your in line draw or node edit was on. In the said software if that was an option.
Thanks for looking at my suggestion
