Surface Patterns
Is it possible to add surface patterns using Millmage? Something as simple as a diamond pattern?..
Yes. Import it as an image, then Trace to convert it to a path.
The catch at this time is that Lightburn does not have a line trace mode. Any line in a graphic becomes two lines, left and right or top and bottom. Some clever editing quickly fixes this though.
Another option is to create your diamond, then use the Array Tool to make a pattern as large as you need.
Sample:
Diamond Grid.lbrn2 (242.5 KB)
Thanks…I could not figure this one out! I appreciate your feedback!tThank you for the reply and sample..
Also, thanks for the sample!
If you select the pattern and click on the Array Tool, you will see that the spacing matches the diamond dimension in X and Y respectively. Took me a few seconds to figure that part out. :grimacing:
Thanks…going to give it a try!,
Did a test with your file and MillMage is milling diamond by diamond 1H29 if you draw parallel lines takes only 44 minutes. Maybe it can be optimized more.
We can Optimize Selected Shapes but the time is the same.
Diamond__Grid.mage (224.6 KB)
Designed in under 2 minutes. That begs for more optimization, for sure.
For different surface patterns, you can also use the new Texturing operation available in version 0.9:
It works only with closed shapes.
You can get nice effects when using a V-Bit:
Oh, and the Fluting Op can do cool things, when applied to individual lines.
This is just a quick draft with a couple random lines and the Array tools
Surface_Texturing_Demos.mage (136.7 KB)
Not yet Mike, not yet :slight_smile:
Thanks Aaron, I will give this a try!
haven’t had change to actually run a centre line yet , but preview looks good
That was posted a month ago. Since then, I got to play with Line Trace in one of the RC’s (MillMage?). Works like a charm!
