SVG and DXF import
Hello, i can’t import anymore .svg and .dxf files from https://www.festi.info/boxes.py/RoundedBox?. Something changed in lightnurn? When i try to do this, nothing happen. It was ok before.
Best Regards
Michel
There is an issue with the file format used by the folks at boxes.py as discussed in a post just in the last few days. This file format change has been addressed and the fixed will be in the next release.
I have to load SVG from boxes.py to inkscape then save as inkskape SVG and working fine.File direct from boxes.py just show empty workspace
Yes, as said, LightBurn is aware of this issue and has a solution ready in the next release. Thank you for reporting this. :slight_smile:
Hello, Thanks all for your answers.i will stop my job until the new release.
Best regards
Michel
