SVG File not importing correctly on my computer, but not my spouse
Hi all. I am a newer lightburn user and have an Aeon Mira 9 laser cutter/engraver. I am running into an issue that I tried to search the forums first for a correction but could not find it.
I have an SVG image which I purchased from a designer. When I import the design to lightburn I then group the image, but there are portions of the design that do not show lines around them as they should. Then when I send it to my laser, there are lines and bands of the design missing. My wife imported the file on her computer with lightburn and it comes up just fine and the entire image is sent to the laser in its entirety and burns just fine. I am at a loss. As I’ve learned, I can’t trace it, so I have no idea why it does it on mine and not hers. Any help would be appreciated.
Can you please load that file on both machine then share a screenshot of the entire LightBurn UI with the ‘Cuts/Layers’ and ‘Laser’ windows showing so we can compare these 2 setups. Start with this and we can go from there.
Are both systems running the same version of LightBurn? Are both systems using the same display mode? (Wireframe vs filled?)
