If you are using the Atomstack A5 Pro in your profile then make sure that the Origin value in Edit->Device Settings is set to bottom-left. I suspect yours is set to top-left or bottom-right if it’s mirrored.
Note that your current saved design will likely flip when you do this. Simply flip the design and resave.
