'Switch Device' prompt when opening file
We have multiple lasers, and run jobs from dozens/hundreds of design files daily. When opening each file, Lightburn continuously prompts the following:
“Would you like to switch to that device?”, asking to switch to whatever laser was active when the file was last saved.
Is there any way to disable this prompt? We recently upgraded from 1.4 and although the recent updates are great, this prompt has made things tedious. I’ve searched in the menus, settings, etc, but no luck.
Apologies if I’ve missed something obvious. Thanks!!!
You can run a fully independent instance of Lightburn with only a “NO MACHINE” however when you design you have to account for different machines working sizes.
Thank you for this potential work around.
Unfortunately I need to be able to also send files to the lasers, so this solution solves one problem, but in turn creates another (having to re open files in the second instance of Lightburn in order to send jobs).
Would be great to simply disable this prompt somewhere in the settings. Perhaps I’ll suggest it as feature request.
Thanks!
