Switching between Galvo to DSP
I have both Lightburn for Galvo and DSP, When I open Light burn it is only opening in Galvo and I do not see the DSP version, I would like to have 2 separate icons to switch between. Can anyone with this have quick answer?
You should have a Device Profile for each machine…
Did you set up a Device Profile for the newest addition?
I do have each device here. I guess I need to plug in and set up while plugged in?
Here’s a video that may help explain. This is showing two DSP controllers, but it’s the same for a Galvo and a DSP. Simply add a device profile for each and switch between them.
