I can not figure out how to switch from a Frame color outline to a line. When I import an SVG to an already open file, it comes in as a frame. What is the most efficient way to bring in files, and to switch from frame to a different line/fill?
I solved this after tinkering for a little bit. I had the “cut selected graphics” switched off for some reason. Going to put the solution here in case anyone else can’t figure this out in the future.
Shift click the layer in the layer list to select all shapes on that layer. Then select a new layer for them from the layer palette at the bottom.
If you use ‘cut selected graphics’, only those that are selected will be sent to the laser…
