Switching from line to fill in cuts/layers window has no effect
if I draw an object (square, circle, whatever) then go to cuts and layers window and switch from line to fill, nothing happens.
What do you mean nothing happens? Do you mean you don’t see the objects become filled in the workspace? If so, it’s likely because you don’t have a View Style set to Filled. You can do this in Window menu.
There are reasons why you don’t necessarily want that on all the time. Primarily, it obscures visibility to how overlapping shapes across layers will interact.
but it does fill when it is sent to the laser
more knobology. ty very much
