T1 / T2 Tools are now cutting!
Using latest version 1.3.01 and recently my T1 & T2 tools are now showing as normal shapes with Speed / Pwr settings. The “Frame” option under Speed / Pwr is no longer there and under “Mode” it no longer says Tool, but Line.
T1T2
I think it may have happened when I was messing with the “Make Default for All” in another Layer’s settings.
Any ideas how I can reset my Tool layers?
You got me… I know you can change the name, but not the layer number.
Was this imported from other software?
Maybe @berainlb knows… I can’t say I’ve ever seen it.
No importing, no. Was a from scratch design.
Like I said, I think it might have been something to do with this default button that may have messed things up?
Can we see some more screen shots of the cut/layers window.
If it was selected as a tool frame, you cannot get to that menu having the default buttons on it…
There is no layer settings for a tool frame, they generate no output.
If you select that layer, can you select from one of the two tool layers, such as the other color one?
The original screen shot is showing only the two layers in the project.
If I create a brand new shape and then select T1 or T2 they are both set to 500 / 100!
No, I was playing with the settings on a standard layer.
I know! That’s the problem!
I have no idea how you did that… or at least got to that configuration…
Might be a good idea if someone like @JohnJohn could shed some light on what may have happened. There is so much to know about variations of machines and how the software handles it, I don’t know what to advise.
Good luck
Ok I fixed it!
I went to a previous project which was ok and exported the preferences, then imported them into a new project and re-opened the broken project and the T1 / T2 layers are now back to normal.
Wierd!
Thanks for the help though!
