T1 & T2 - Ver 0.9.24
This is from the documentations:
This is my color palette:
This is my Layers settings:
ice_screenshot_20210717-155839
Shouldn’t i be seeing T1 & T2 in the color palette at the bottom rather than 30 and 31?
Hi, i’m sure mine used to be ‘TI’ ‘T2’ but now it’s ‘30’ and 'T2’so not really sure :thinking:
@Squid and @Kris1 That is a odd and definitely should not be the case.
Can both of you please go to Help > Generate Support Data
And then paste that big block of characters here (it will automatically be copied to your clipboard).
That will give me everything I need to debug.
Thanks!
T1 T2 .TXT (11.1 KB)
Hope this is what you were wanting and where you wanted it :thinking:
yep! thanks :slight_smile:
You should be able to put this stuff in a file, drag and drop the file on your browser window to upload with your edit. I think I’ve done this.
My Data Attached.
Thank you.
Squid-Support-Data.txt (7.5 KB)
looks so much better. :roll_eyes: :+1:
@Squid - sorry for the delay. would you mind uploading your actual prefs.ini file (File > Open Prefs Folder) here?
I’m seeing some really weird stuff when I try to load it from the data you gave me and just want to rule out a problem with the support data encoding.
