Tabbed Views instead of new "windows"?
Is there any possibility to moving to a tabbed windows environment instead of opening a new window? I have three lasers hooked up to LB but additional windows are clunky. LB is fantastic but frequently, I need several windows open instead of discrete app instances. If it’s not on the roadmap, no problem, but I thought I’d throw it out there. Cheers!
No, to have multiple projects at the same time, you need to open additional instances.
Either you have to switch between sessions or have 2 additional computers or laptops to service 3 laser machines. Since it doesn’t require that much processing power, an older computer will be fine.
I have 2 old (Linux) computers and 2 Macbooks that I can use at the same time, but usually I only design on one computer and produce on another. When I run serial production, which is not that often, all my attention goes to the specific machine, but an engraving job of an hour will give some extra time for another projects…
