Table area and software area seem to be offset
I have a Neje Max 4 with the extension kit so the area is 29x40 or 750x1030. I have those settings in the software and teh machine will home. If I click the move button though the laser head moves very differently than the point I click in the software. It’s almost like the software area begins in the middle of the table. I’m trying to rtfm, but i’m not seeing anything. This is my first setup any help would be great. Thank you. Found the setting change in the machine setup. Can’t delete post though
Let’s start with some basic info and I’m sure we can get you going.
You said it homes correctly. Does this mean that it has limit switches? Which corner does it home to? What Start from setting are you using.
Post a screenshot of your entire Lightburn screen with the Cuts/Layers Panel and Laser Panel visible. Also post a screenshot of the Settings Window (Gears icon) with the Units and Grids tab visible and post a screenshot of the Device Settings Window (Wrench and Screwdriver icon).
Sorry I found the document that said you have to change the dimension in the machine settings under the output section.
Thank you for responding though. I don’t even know how I found the video the documentation is not very strait forward. Again thank you for looking at the post
