Table Part Movement
Hello All,
Just had a question on the part movements on the table. Example, I have drawn a 1 inch square on the table, and when I drag it, the square moves about three inches in either direction I drag it. I have the snap to grid and snap to part both turned off. In the movement window, the movement interval is set to .394.
This is really hard trying to be able to move parts close together. It is something in the settings that I can’t figure out. Thanks for any help on this from any one.
Thanks,
Tim
I am having trouble determining what this is. Can you make a screen grab of what you are referring to?
Thanks for the reply. Before, if I made a square and copied and pasted it, I could just
drag the pasted square to the edge of the original one. Now it seems as a snap distance is set at about an inch or so. Like I said, all the snaps are turned off. Yes before I could just manually drag parts edge to rough edge. I don’t think by accident I turned something off, But ???
Thanks
Tim
I’m still kinda new to lightburn myself but it appears that snap behavior is relative to zoom level. Try zooming in closer before moving the shapes near each other.
A workaround more than a fix but should get you by until you get a better answer.
Might breeze over the documentation, it’s pretty short…
Did you try moving it using control, alt or windows key?
Thanks all on the replies. i will look into it all.
Thanks,
Tim
Hold down the Ctrl Key and use the Left Right Up Down Arrow Keys to move the design in small increments.
Thanks baricl317
