I am trying to make my own box dividers (below image). I want to make this tab 1 inch in depth?
I don’t understand the use of a “tab” in this case. A tab is used to hold a part in so it won’t drop out till you push it put with your fingers. If you want to make a “slot” for dividers, then make a rectangle the with and depth you want and use the Boolean operators to put the slots into the long piece.
Thanks for quick response. It didn’t take much to confuse me, but I got it now. Dividers are working great!
