Fairly new to Lightburn but under the move window there are tabs to adjust speed and power.
Do these alway supposed to work or can they be disabled? Mine do not work or adjust the speed up or down or increase or decrease the power. Is there settings that effect thus?
If doesn’t works means that your machine is not connected, what do you see in console tab?
From what i understand i thought these adjustment tabs can be used while laser is engraving. The machine is obviously connected to pc as i watch it engrave and want to make changes.
Sorry i misunderstood what you mean, i’ve still open a bug cause if yours doesn’t work, mine made my job stop and move head back to origin.
To have help please tell staff what laser is and what OS are you using
Not sure what you mean by “tell staff” I am using a windows 10 operating system.
I mean that if you can’t modify power and speed while engraving you have to tell at @LightBurn_Staff that you have that issue also telling them what OS are you using and which control board
