TABS- The vague, the confusing, the shy
Well unless I’m missing something with TAB generation (possible).
  1. Manual tab generation seems to be a two part deal. Ticking manual tab generation does nothing, you have to go to another icon to place them. Not intuitive to me.
  2. Clearing tabs does not untick the tab generator. Why is it ticked if there are no tabs? You have to go and click the tabs icon to find out if you have any.
  3. Why do they not show up in the preview window? Anything the laser is going to do should be shown in the preview. :man_shrugging:
Not intending to take sides, I’ll give my opinion:
A “TAB,” in my view, is a new line superimposed on another, with different settings from the main line. Therefore, it should be considered as such. (A line with different definitions) Keeping this aspect in mind, I believe it makes sense to treat it differently from other lines.
This happens when you are inside the layer settings. In my view, as in any other settings window, you have to exit it to change the drawing. Outside, by clicking on the TABS icon, you insert (in manual mode) the necessary tabs at will, wherever you find it most useful.
I would swear it’s just icon management. I understand the point of view, but I believe it’s the same as when you draw a line and need to press “Esc” or another icon to “disable” the function. Any developer will be able to justify this better than I can.
I would say that either you don’t have tabs, or if you do, they are not selected on layer settings window, or they are too small and you will only find them by enlarging the preview image.
In version 2.0.05 they are there.
I leave a line with 5mm tabs just as an example and to show the tab in the preview image.
I have 4 tabs on this layer, I do see 2, can you find the other 2? It’s like where’s Waldo.
Now add in the rest of the project and find the tabs.
It sounds like you’re requesting better tab visibility in Preview, which would be a good request over on lightburn.fider.io
Okay, I understand the problem. They appear and are there, but they’re either very hard to see or go unnoticed.
I insist, it seems like I’m defending the software with all my might, but that’s not the case.
What has happened to me that’s identical (problems with visualization) had to do with the monitor resolution. If increasing or decreasing the size of the preview window (not zooming) causes the “hidden” tabs to appear randomly (depending on the window size), that’s a problem with the monitor resolution.
Apart from all this, highlighting the tabs with a line of a different color (for example) in the preview window seems like a positive thing for everyone.
The link left by @Colin is the ideal place to go to see this become a reality.
I agree that making a feature suggestion, which I did is the proper way to handle it. I also think that posting on the forum might help bring attention to these things as just posting on feature suggestions feel like a black hole. Trying to work all the angles.
This I agree with. Maybe there should be a Forum Topic for suggested features. Just to help the suggestions to get more attention. that way it would show up in the New, Unread, or Latest postings list.
Well first I had to go look to make sure there wasn’t one, and you weren’t just mocking me :wink:
I think there should be and didn’t think about this as an actual topic. So the forum is already proving itself in the idea realm.
I believe that this would make for better feature suggestions. And devs could monitor the interest generated and a lot of times the suggestions have a solution that the poster didn’t know about.
A forum topic on this might be a better solution. More heads could make for better suggestions.
@Kuth brought up some good points and in the end I realized some of the problem was how I was trying to do things.
In the end though I have concluded that there is just not a enough visual clues to let you know if you have tabs in your project or not.
I agree with you, for example, I do sporadic projects, and I don’t always remember all the software’s potential, sometimes because I don’t know it exists.
Undoubtedly, a topic highlighting an idea that could be useful to everyone would bring it to the attention of others who, if interested, could go to the indicated place to vote on that idea.
Although, on the other hand, I and all of us should sometimes consult the page https://lightburn.fider.io/ and vote on what seems or is useful.
However, the topic clarifies the reason or reasons behind the idea. In my view, sometimes an idea doesn’t go beyond that simply because we don’t know the reason behind it.
