Using LB for some time now, I’m frequently missing a function to generate tangents to circles. I know how to construct them “from cratch”, but unfortunately it’s time consuming as LB does not support creating a (Thales) circle on line non horizontal or non vertical.
I’ve read in an old thread, that years ago somebody was asking for it, but at that moment and time there were no supporters on this proposal. Consequently nobody took care of this request. I would like to try once again to motivate the developer team to put this function on the “to do list”. Are there any supporters today out there?
Maybe the development could be based on the “Tangent Circle Generator”.
Can you show a small example of how and for what you want to use what you are rewriting, it gives a better understanding and the opportunity to see if there are alternatives.
If you want a line tangent to 2 circles, draw two circles, select them, then Arrange> Create rubber band outline from selection. This draws lines tangent to the 2 circles. Then, delete the 2 circles.
If you want to draw arcs that are tangent to 2 circles, Draw 2 circles. Then select them, and Tools>Generate tangent circle, and pick the option you want.
didn’t know that feature. It’s good to generate so called “outer tangents”. I need to draw “inner tangents”. Unfortunately I don’t know how to post a picture but I try to discribe in words what I mean.
If you construct inner tangents to two circles, the tangent lines a crossing themselfs in between the circles. Any idea how to do this?
the tangent circle function is fancy but I don’t know what to do with it. In any case it doesn’t help for the inner tangents. I will try to put it in the feature suggestions and wait what happens.
I agree with @RalphU. This is what was LineSnap to Tangent in a CAD/CAM system I was a trainer for. But your application is so specific that I cannot visualize why you need it. For those once-in-a-while situations, use a freebie software that can do it. I bought a low cost (<$100) package that had this capability because I figured my WinXP would eventually croak. Have not touched it since I got Lightburn.
I also had a bit of trouble visioning what You need it for, but that makes perfect sense, thanks for the clarification.
Anything like that shouts -if not screams- the use of a dedicated CAD software, even a simple free one like Opticad.
A parametric CAD like Freecad for example would obviously allow easier changing of the parameters instead of drawing the pattern over and over again, but the learning curve can be overwhelming to say the least if AutoCAD 2D derivatives is the only types that one are familiar with.
OTOH, a shape like that takes only a few minutes in CAD, so in simple shapes with only a few parameters the time savings are neglible.
While “snap to tangent” for example in this case may feel like a simple piece of code -after all we’ve had it in CAD software (even in free ones) for decades- coding something like that into a software that isn’t a CAD software and isn’t even intended to compete with them might be tricky or even inpractical.
I do wholeheartedly agree that “snap to tangent” among several other powerful and familiar to us time saving CAD-tools would be a nice addition to LB.
But on the other hand, the same time I don’t see much sense in stretching limited coding resources in benefit of a minority us engineering types most likely are, especially when those tools are availble for free in other software.
And as it’s more than likely that we (know how to) use them anyway .
What (too) little laser stuff I’ve been doing lately, I’m absolutely certain that I use only fraction of the current LB capabilities, and mostly design in CAD and only do the laser control stuff in LB, so I definitely am biased, that’s for sure .
Don´t know if you know this.
You can add the glueline or other design to the Art Library to use in other projects.
Example of a trace from your glueline and a modified one.
To apply this just Ungroup, put the glueline in place, select both shapes, duplicate, move aside then apply the Trim Shapes Tool to the downside of one copy and the upside of the other copy, remove the remaining “trash” shapes and lasercut.
I have a Turbo CAD license but I use LB much more than TCAD. In addition to that I still think that it would be much more convinient to have the “snap to tangent” function in LB as it’s not the first time I have to glue together two pieces.
Having said that I’m not complaining as I’m only a poor LB user and not able to contribute to programming and maintaining of LB. I only saw in the request list that I’m not the only one askiong for this function.
Anyways, I will try out the art library, maybe that’s a feasable workaround. In case not I still can go on constructing the inner tangents, which is not complex for an engineer but only time consuming.
