Hi.
Tap generation with errors, since it does not change the options, it only leaves me once and then if I want to change to more points, it does nothing, it stays the same as the first change, I would like to know if it is a program error or something I am doing bad, I hope you can help me.
Note. Changes in the layers window if you make them, but when opening the preview window, or when cutting, it does not apply the changes
