Tengo un error alarma 3 - Creality falcon 2
Buenas noches. Me tira una error el laser. Lo puedo mover manualmente desde el programa, y si pruebo un disparo, tambien funciona. Pero cuando le doy en marco no se mueve y me realiza un pitido. Y me tira el siguiente error en la consola:
<Idle|MPos:0.025,0.025,0.000|Bf:127,65535|FS:0,0|WCO:0.000,0.000,0.000>
ok
<Idle|MPos:0.025,0.025,0.000|Bf:127,65535|FS:0,0|Ov:100,100,100|A:S>
ok
Comenzando transmisión
Transmisión completada en 0:00
ok
<Idle|MPos:10.025,0.025,0.000|Bf:127,65535|FS:0,0>
ok
ok
ok
<Idle|MPos:20.025,0.025,0.000|Bf:127,65535|FS:0,0>
ok
ok
ok
<Idle|MPos:30.025,0.025,0.000|Bf:127,65535|FS:0,0>
ok
ok
ok
<Idle|MPos:40.025,0.025,0.000|Bf:127,65535|FS:0,0>
ok
[MSG:Using cpu_map…esp32-s3]
Grbl 1.1f [‘$’ for help]
Si alguien sabe que puede ser, y la solucion, les agradeceria que me ayuden. Gracias!
Your Console text does not mention an error. However, Error 3 says a possibly bad specific S (spindle, laser power in Lightburn) instruction.
My best guess is that you either have a power setting not compatible with your controller (like maybe you entered 25.8), or you have Enable GCode Clustering turned on.
la funcion Habilitar agrupación de GCode la tengo desactivada. Como corrigo o me fijo la configuracion de potencia? Gracias
Esto me sale en la consola si pongo iniciar
ALARM:3
Reinicie mientras está en movimiento. Grbl no puede garantizar la posición. Es probable que se pierdan pasos. Se recomienda volver a retornar a 0.
On or near line 15:
Stream completed in 0:00
This video may help…
