Tengo una falla en la maquina sculpfun s30 pro me marca falla ALARM:9 Error en el ciclo de autoguiado. No se pudo encontrar el interruptor de límite en de la distancia de búsqueda. Definido como 1.5 * max_travel en la búsqueda y 5 * pulloff en las fases d
This is telling you, if the laser is hitting a limit switch. then the switch is not being detected.
  1. The switch is defective.
  2. The wiring is broken.
  3. The switch position has moved and is no longer being actuated.
  4. Check to be sure the switch has not come loose.
  5. Use your finger to actuate the switch and listen for a clicking sound.
al actualizar a la version 1.7,04 esa falla me marco a mi en mi S30 Ultra de 33 wats tambien necesito ayuda
Alarm 9
“Homing fail. Could not find limit switch within search distances. Try increasing max travel, decreasing pull-off distance, or check wiring.”
The firmware searches for the limit switches in the set direction. The track being scanned cannot be longer than the maximum size of the work area. So if the laser has traveled further than the set length in $130 or $131 and has not found any limit switches, this alarm is triggered and the laser is stopped.
Still saying it was not Lightburn. HOWEVER, sometimes Lightburn parameters are not carried forward with a new install. Nobody knows why, and makes sense considering the variety of Windows and Apple operating system installations. Reload a copy of the LBPREFS file to see if that clears up the problem.
