Tete laser incontrôlable
Bonjour
Je viens de faire l’acquisition d’ un two tree ts 2 20 w.
Probléme, quand j’active lightburn la tête qui supporte le laser part tout en bas vers la gauche sans s’arreter.
Je suis obligé de faire un arrét bouton.
A quoi est- ce du?
Merci de votre aide.
'Hello
I just bought a two tree ts 2 20 w.
Problem, when I activate lightburn the head that supports the laser goes all the way down to the left without stopping.
I have to do a button stop.
What is the cause of this?
Thank you for your help.’ - Translated by Mod
It sounds like you need to change your Origin in your ‘Device Settings’. You can find this setting by going to ‘Edit’ > ‘Device Settings’, or by clicking the wrench icon in your top menu bar.
The ‘Device Origin’ setting controls the orientation of what gets sent to your laser. If you have the origin for the device set incorrectly, your output will be mirrored or upside down when run, or may home to the wrong corner.
Thanks a lot for help
Disable auto home on start and problem fixed.
Merci !!
