Text bending - no diameter information
Hello, I just started using lightburn and I ran into a problem and didn’t find a solution. The problem is that the software has a very easy way to bend the text (this small circle when you select text), but there is no information anywhere about the diameter of the circle and where its diameter changes? The second thing is that when I bend the text, the height of the entire text field changes, which is understandable because by bending we change the value of the height and width of the text field, but at this point I do not know what the font height in mm is (not the font size value). There should be a separate menu somewhere for text management, like in ezcad, where even after bending the text there is still a special menu where you can view or change the values of the already bent text. Regards
If we’re wishing…
I’d love it if I could “unbend” text that had previously been bent. Sometimes I’ll be playing around with a design and decide I’d rather go back to straight text but undo…undoes …too much other work to make it useful. Yes, I can eyeball it or build a new text entity or work from duplicates… But, we’re wishing, so…
