Text distribution around a ring
I am trying to engrave the outer surface of wooden napkin rings with two copies of name-text separated by a bullet-point. I’m having difficulty getting the image to distribute evenly around the ring. I’ve explored the tools and searched online but have not found a solution. Any help appreciated.
If you can post the .lbrn2 file, it would benefit us by seeing what you have…
It’s had to advise with no other information…
Hi Jack. I’ve not done posted before so I’m hoping this works. — Mike
Ring _LB1.lbrn2 (24.1 KB)
Are you using a rotary tool to rotate the wooden napkin ring?
A picture of the napkin ring and the uneven distribution would be helpful for folks trying to understand and assist.
Yes. I’m using a rotary attachment.
