A software update was apparently interrupted and corrupted causing my machine not to startup. Fixed. Reinstalled Lightburn. … but the text typed - although fill in is selected - it’s showing line. How do I fix it? This new install seems diff than my previous installed version. Can’t remember version number of prior but this one is 1.7.03 and auto updates are on. How do I get it working correctly? TIA
Laser info: Longer Ray 5 20W on a Lenovo Yoga Windows 11
FYI, by default LightBurn works in Wire Frame mode, just like you’re seeing. Working in Filled Rendering mode can hide things behind objects, producing unwanted results. Running a Preview will show things filled, as they will engrave. You can always turn on Filled Rendering mode like was show, but be aware of the caveats. You can quickly toggle filled rendering with the ALT+SHIFT+W hot key on the keyboard.
