Before you had replied I somehow got the red dot to appear again when I move the laser so that is working. however, whatever I did now moves my laser at a snails pace. the other problem I have is the text I type in appears correctly from left to right but when my laser does the fill the text is reversed, goes from right to left.
ok speedis not ok, Thank you.
The only other setting I have to change is the text being reversed, shows L to R on my computer screen but the text is backwards from R to L
Yes, I understood that from your previous post. This is the reason I provided the ‘Output issues’ link to our documentation, where is says:
Output is mirrored or backwards
The ‘Device Origin’ setting, found in the menus under Edit => Device Settings, controls the orientation of what gets sent to your laser. If you have the origin for the device set incorrectly, your output will be mirrored or upside down when run.
For DSP controllers (Ruida / Trocen / TopWisdom / etc) the Origin setting for the device should match the corner that your laser homes to when first powered.
The four dots on the Device Settings page, Origin, control the output. Simply flip this setting to change this. You may need to flip the artwork after changing the Device Settings Origin.
