Text moves rather than cursor moving
Simple question on an issue that should’t really be an issue. When I type text I select a place on the workspace and the text moves to the left as I type. Is there a way to make the cursor move instead?
This is because of the current Align X setting. To have the behavior you describe, change this to align ‘Left’. :slight_smile:
A long the top with the other text setting (font, size, etc) is your alignment set to “right” by chance? If so, try changing it to “left”.
Ah, so simple. Thanks!
