I created name plates in LB 1.04.05. Later opening the file in LB 1.7.3. and saving the gcode to import it in to Luban to send it to my Snapmaker A350T for execution. The Luban preview of the imported showed the text no as outside of the cutting area for the nameplates.
I reopened the file with LB 1.04.05 saved the same content out to a new gcode file and uploaded this file into Luban the preview showed the text aligned correctly in the cut boxes. I checked both versions and they shared the same optimization settings and both were using the Snapmaker A350T device selection.
I’d really like to use LB 1.7.3 but Text not printing where is supposed to pretty much kills that choice. Lightburn showed the text in the same place across both version when it was being generate from the same source file something is going wrong in the g-code generation. I attempted to diff the files but don’t have sufficient experience to suss out where the problem resides.
I am going to upload the respective nc and lbrn2 source files as well as 2 png files that show the Luban import screenshot illustrating the problem.
Micha-60x18mm-V1-lb1.7.3.nc (137.5 KB)
Micha-60x18mm-V1-lb1.4.05.nc (134.2 KB)
NamePlate-60x18mm-V1-lb1.4.05.lbrn2 (18.7 KB)
