I have created a few files (.ai .svg) that have a graphic with text below and when I import them the graphic shows up but the text does not. Any suggestions?
LightBurn doesn’t support all the different text options that many art packages do, so rather than try to explain to users why their text sometimes looks different, we just require all text be converted to paths for the time being.
Make sure you right click on the text while in Illustrator and select “create outlines” then save. The letters should show up in LB when saved as an .ai file.
That was it thank you!
